Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Hotrodding Basics
  #1
Old 07-14-2007, 08:34 PM
mhalll_32 mhalll_32 is offline
the difference in a 327 and a 350?
Im new at this whole thing and i just got a 85 chevy short bed truck and if i put a 327 in the truck will it be faster then the 350 and what is the difference between the two?
Old 07-14-2007, 08:37 PM
38gangster 38gangster is offline
Destroy this 350 trend
re: the difference in a 327 and a 350?
the 350 is overrated. hahaha
Old 07-15-2007, 12:11 AM
So what your sayin is that the 327 is a better motor and that i should put that in mt truck?!?! Also which one is better on gas cause i heard that the 327 has bigger pistons and is worse on gas?
Old 07-15-2007, 01:59 AM
327NUT's Avatar
327NUT 327NUT is offline
The 327 and 350 share the same 4" bore size, the the 327 has a 3.25" stroke crank and the 350 is 3.48". The 62-67 327 is a small journal crank, 68 -69 they went to the large journal crank. Theoretically the 327 should get better mileage since its a smaller cube engine but that all depends on how the engine is equipped and how heavy your right foot is.
Look at www.mortec.com and you will see that some casting numbers like the 010 blocks were used to build some large journal 302, 327 and 350 engines. And again theoretically. if you have 2 exactly equipped engines, one a 327 and one a 350 then the 350 should put out more torque and hp due to it having more cubic inches. Do some reading before building either engine, might save you some grief later.
Old 07-16-2007, 01:13 AM
need to go mopar
Old 07-16-2007, 05:09 AM
Blazin72's Avatar
Blazin72 Blazin72 is online now
Realign your connecting rods..
 Blazin72's barnstar
Wiki Edits: 19
mhall, 327nut explained it pretty well. There really isn't a tremendous difference between the two engines. Think of the 350 as the natural progression in engine size from the 327. All I have to suggest is that if you have a truck then you'd probably be better off with the 350.
Old 07-16-2007, 10:32 AM
hyarbour hyarbour is offline
If two vehicles were equiped with identical gearing and tires, the one with the 327 would win. It can reach a higher RPM due to the shorter stroke.
Old 07-16-2007, 11:34 AM
ChevelleSS_LS6's Avatar
ChevelleSS_LS6 ChevelleSS_LS6 is offline
No celebrities for presidency!
 ChevelleSS_LS6's barnstar
Wiki Edits: 3
x2... 350 is a long stroke 327. 302s are short stroke screamers, as are the 327s. 350s are good all around. Use the same intakes, cams, etc... just the same cam in a 350 is 'bigger' on the 327 and the 302. I think. Am I right?
Old 07-16-2007, 11:39 AM
As far as I know the only differences are the crank and pistons (diffirent pin height) everything else is the same.
Old 07-16-2007, 05:59 PM
Blazin72's Avatar
 Blazin72's barnstar
Wiki Edits: 19
If both vehicles, including engines, were built the same. The one with the 350 should come out on top. The 350 will make more power and more torque, therefore accelerate the vehicle faster. Just as a 383 would be more powerful, and therefore faster than a 350. As I said before, since you're dealing with a pickup then the extra cubic inches will only help. You could even consider stroking that 327 (if it's a large journal block) or that 350 to a 383. Cubes can be an engine builders best friend.
Old 07-16-2007, 08:20 PM
boatbob2 boatbob2 is offline
boatbob2
327 Versus 350
Hi,the difference is 23 cubic inches...
Old 07-16-2007, 08:38 PM
redsdad redsdad is offline
Will I ever get it done?
Absolutely. The only substitute for cubic inches is rectangular dollars.
Additionally, the longer stroke translates to more torque for a given MEP. This is particularly important for a street engine where you spend most of your time in the lower rpm range, not in the trees.
Old 07-21-2007, 08:02 PM
larryblack's Avatar
larryblack larryblack is offline
Certified Lead Foot
Location: Red Stick, Cajun Land, The Dome, TX and I-10 in between.
IF you modified a 327 and 350 exaxtly the same, they will both perform almost identically the same. The 350 will develop better torque sooner giving it a decided pull ahead advantage. since hp is torque times rpm divided by 5252, you get higher HP at a lower rpm. The 327 theoritically can out rev a 350, but torque makes LOWER ET's.
I have turned a properly set up 350 to 8500 several times.
much of the "old wives tales" that say the 327 was a better engine comes from the fuelie vette motors. The highest rated 327 was 365 hp. That motor was around for a few years of production. Folks remembered that more so than the 370 hp 350 1 year LT-1 vette motor. the LT-1 motor was also not rated to turn as high of an rpm to make the 370 hp.
Remember, both motors were originally and primarilary low hp passenger car motors.
Old 07-21-2007, 09:11 PM
327NUT's Avatar
Sorry Larry, the highest rated 327 was the '64 -'65 Fuel Inj. L84 Corvette at 375 hp. The '64-'65 L76 327 Corvette was 365 hp. This is well documented, see www.enginefactory.com/corvette
Old 07-30-2007, 10:18 PM
J.D J.D is offline
O.K heres a question,What is a nice combo (BUdget) for a street 327,1968 camaro RS ,2 speed PG, Not sure of the gear. 125 shot NOS. I have a 465/488 lift cam I could use (hyd). I have some 350 alum. 202 heads also.What else would Be a great motor for this car.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
