Difference AOD-E & 4R70W - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2005, 05:54 PM
Hello, I was wondering if someone could help me out. What exactly is the difference between the AOD-E and 4R70W. Is the 4R70W just a wide ratio AOD-E? Anything would be very helpful. Thanks
Paul
Old 05-02-2005, 07:09 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
well, yes & no.
Gear ratios are different.
Depending on what years of AODE & 4R70W you are comparing.
Ford used both at the same time for a while and they will bolt in place of one another......... BUT , you will get a trouble code with the vehicles computer that a gear ratio ERROR has been detected.
AOD to 312 57 T-bird BarryK Transmission - Rearend 1 03-09-2008 02:24 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
My AOD, the full story mustang66maniac Transmission - Rearend 26 01-30-2003 04:38 AM
AOD to 4r70w gear swap 5.0Towncar Hotrodders' Lounge 2 10-12-2002 06:17 PM
AOD to 4r70w gear swap 5.0Towncar Transmission - Rearend 0 10-08-2002 02:17 PM
