Difference Between dish and flat piston - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2005, 09:22 PM
Parisienne70's Avatar
What the difference if i put a 461 head 64 cc with 2.02 and 1.60 valve
on my block with dish piston or Flat piston
Eric
Old 02-15-2005, 09:27 PM
engineman302's Avatar
Last journal entry: again
the diffrence be more higher comp. ratio with the flat tops than the dish.
Old 02-15-2005, 09:36 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
dish vs flat
According to JE pistons with a 350 block. The dished piston is 8.5 to 1 compression and the flat top is 10.4 to 1 compression. At a .020 bore.
Old 02-15-2005, 10:10 PM
camaroman7d's Avatar
One MAJOR detail has been left out, how big is the dish? This will make all the difference in the world.
If you are trying to figure out your compression ratio you need to know your stroke, rod length (to firgue out which piston), bore, head chamber cc, head gasket specs, and how far in the hole the poiston is at TDC (top dead center).
