Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Difference between non-lock up and lock up transmissions beside the torque converter
Old 06-03-2011, 08:39 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
When a 2004R's converted to use a Non-Lockup TC, the Check valve w/Retainer and O-ring is removed from the end of the Input Shaft. The TCC valve & TCC Solenoid is removed from the Pump and a Non-Lockup valve is installed. So reverse this & get a Lockup TC + Lockup kit or DIY kit & your set.
