Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Difference between non-lock up and lock up transmissions beside the torque converter
Old 06-04-2011, 09:23 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Originally Posted by cool rockin daddy
A lock up converter will save you gas, will cut down on slippage therefore reducing tranny killing heat, and saves wear and tear on the trans. Do I have to take this sucker apart to do these things or should I ship it back?
Check to see if the Check valve capsule & O-ring are in the end of the Input Shaft 1st.
Part #'s 380 & 480 here>> http://www.bulkpart.com/Merchant2/gr...pdf/200-4R.pdf
Only have to drop the Pan for the TCC valve & Solenoid.
The Non-Lockup valve replaces this>> http://www.sonnax.com/product-lines/...ion/parts/3099 and the Solenoid goes in the same hole last, here>> http://www.montecarloss.com/TCC_5.jpg
