Difference Between Th350c And Th250c - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2005, 01:52 PM
Anybody Know The Difference??
Steve
Old 03-11-2005, 01:58 PM
poncho62's Avatar
Wiki Edits: 5
Yeah....one is JUNK and the other is not..............Guess which?
250s are much weaker than the 350s. Get a turbo350, it's a direct bolt in.
Old 03-12-2005, 07:38 AM
tnsmith10's Avatar
when will it rain???
the th250 will have a stud with an adjusting nut on the upper right side of the case for the band. the th350 doesnt. hope this helps.
Old 03-12-2005, 08:24 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the adjusting stud with nut that tnsmith10 is talking about is in the area of the cooler line fittings on the p****enger side of the trany. It protrudes form the case.
the T-250C does not use a set of frictions for 2nd gear. It uses a narrow band for 2nd gear.
A weak , non performance tranny
Old 03-12-2005, 06:28 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I combined this information in my Transmission Information sticky post, and gave you both credit for it.
