i did some digging around and it looks like these pumps flow 190LPH
190lph = 50.1GPH
302LB/HR divided by BFSC of .62 = 480hp per pump at 43 psi
so these 3 pumps should support just shy of 1,500 hp @ 43psi of fp if the info i found on them is correct
and just to compare them to the aremotive pumps
340LPH=89.9GPH
540LB/HR divided by BFSC of .62 = 870 hp per pump at 43 psi
so both pumps should be able to support 1700 hp
granted hp able to be supported will drop as pressure goes up unfortunatly i cant get a flow sheet for the zr-1 pumps
but hell it looks like the zr-1 pumps might just stay in the car even when i get my 340lph stealth pumps back from areomotive
