difference between tpi fuel pump and corvette zr-1 fp? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2011, 09:52 PM
Project89's Avatar
does anyone know what the differences are
i have 2 areomotive stealth 340lph pumps in my car that are going back to areomotive under warrenty
so for the time ebing i found 3 pumps on ebay to throw in the car for now so i can drive it around
there are listed for a 5.7 vette zr-1 dohc motor i bought 3 of them for 15 bucks each new
Old 11-09-2011, 12:33 AM
Project89's Avatar
well i know the pumps are 3-4 bar pumps so the presures are the same as the stock camaro pumps, does anyone happen to know what the flow rating on a corvette zr-1 pump is
Old 11-09-2011, 12:55 AM
Project89's Avatar
i did some digging around and it looks like these pumps flow 190LPH
190lph = 50.1GPH
302LB/HR divided by BFSC of .62 = 480hp per pump at 43 psi
so these 3 pumps should support just shy of 1,500 hp @ 43psi of fp if the info i found on them is correct
and just to compare them to the aremotive pumps
340LPH=89.9GPH
540LB/HR divided by BFSC of .62 = 870 hp per pump at 43 psi
so both pumps should be able to support 1700 hp
granted hp able to be supported will drop as pressure goes up unfortunatly i cant get a flow sheet for the zr-1 pumps
but hell it looks like the zr-1 pumps might just stay in the car even when i get my 340lph stealth pumps back from areomotive
95 gmc jimmy fuel pump won't shut off/fuel pump relay garystrosnider Electrical 7 10-28-2010 07:10 AM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
Troubleshooting Fuel Pump Power on 87' Corvette edge Electrical 1 07-02-2006 06:12 PM
SBC 'Short' Water Pump vs Corvette Pump ezobens Engine 4 03-20-2006 10:36 AM
TPI 350 fuel pump *VERSUS* a Multiport 2.8L fuel pump boneyard Buick Engine 0 03-18-2006 09:40 PM
