Difference in "latching" and "momentary" switches? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2010, 02:54 PM
labreejr's Avatar
I'm looking for a cleaner look in my 84 Cutlass, so I'm routing the switches for headlights, wipers, door locks and power windows to the center console. I'm looking at the push button switches from Autoloc with the led ring around them. They have 2 types.......latching and momentary. Whats the difference. From what I understand, the latching is the same as a back/forth-on/off rocker switch(correct me if I'm wrong). The momentary I'm ASSUMING issort of like the horn button, as in it operates the function as you're holding it but when you release it disables the function??
Thanx in advance for any info.....................
Old 10-19-2010, 03:03 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
A latching switch stays down when pressed and a momentary switch doesn't.
Cole
Old 10-19-2010, 03:09 PM
You got it right! You answered your own question. When you get it done post some pics.
Old 10-19-2010, 03:24 PM
eloc431962's Avatar
Wiki Edits: 37
Right on Chris.
Cole
Old 10-19-2010, 03:39 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
You also have to consider the "Fail Safe" of the switch. This means, when you cut the power off from the switch will the switch remain 'open' or 'closed'. Case in point; If you have a latching switch that activates a solenoid that keeps a trunk lid closed, what happens when the power is cut to the switch i.e. dead battery or cut battery cable? Does the switch 'Fail Safe' to the normally OPEN or CLOSED position? If your battery was in the trunk, you would want it to Fail Safe in the N.O. (open) position so that you could get in the trunk to service the battery, rather than the N.C. (closed) position where it could not be opened unless you had an outside release (mechanical release).
The choice is yours.
Old 10-19-2010, 03:49 PM
Wiki Edits: 647
Further to the above, if you had a power antennae that you wanted to go down to keep the car clean (looks-wise), you would install a N.O. switch that would apply power to the switch to retract the antennae when the radio or ignition switch was cut off. And you would want the reverse affect when you turned ON the radio or ignition.
Not so confusing, now!
Old 10-19-2010, 03:51 PM
eloc431962's Avatar
Wiki Edits: 37
alittle1 has made some very valid points here and you do really need to take all this into consideration. JMO
Cole
Old 10-19-2010, 05:47 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
The Autoloc term "latching" must be referring to a push ON, push OFF type of switch. This is actually a maintained type of switch like a toggle switch.
The momentary switch is exactly that. As long as you are pressing the button the circuit is made. Release the button the circuit opens.
vicrod
Old 10-19-2010, 06:09 PM
labreejr's Avatar
Just got confusing. I dont see them mention anything of N.O. or N.C. Or would I have to wire it that way. And I'm assuming I should want it "fail safe" considering the batteries are going in the trunk..........Thinking of putting a positive jumper under car some where or in a wheel well.
Kind of to the effect of electric fans coming on when the car is off to cool it?
Old 10-19-2010, 08:19 PM
bubbahotep's Avatar
Too much mixed info confusing you. lol
Switch are NOT the same as relays so a latching switch simply stays in the last position you left it in regardless of power. Like the headlight switches in old cars are latching, leave your headlights on too long and the battery dies. Wall switches for home lights are latching
Power window youd want momentary: windows go up or down only when held pressed.
Locks: Momentary type
Lights: latching so they stay on without finger holding em on all night
Call or email the sales people to confirm what you need. Lock switches would have many terminals because they reverse polarity to open or close the lock etc.
Old 10-22-2010, 04:39 AM
Both a toggle and a latching switch will keep the last setting, even if power is turned off. However, they are designed differently
A latching switch is usually a "push on", "push off" button, like you find on some foreign cars for the A/C compressor. Push it once to turn on, push it again to turn off. It has a spring and a latch built in to the switch.
A toggle switch uses a lever or paddle, and you simply move it up and down between positions. Some are On/Off, and others are On/Off/On, where you can feed two different accessories.
Single pole, single throw - simply on and off
Single pole, dual throw - on/off/on
Dual pole, single throw- on/off for two accessories (maybe left and right side lights)
Dual pole, dual throw - on/off/on for two power feeds (the dual gas tank switch on my truck uses this to switch both the gas gauge and the fuel tank solenoid at the same time)
Switches can also be designed to light up when turned on, or they may have a separate power feed for a backlight that is controlled by your dash lights.
If you are going to rewire your entire dash, make sure you separate the courtesy light circuit, because it works differently. The dash accessories are grounded all the time, and you switch power to them on and off. The dash lights are the opposite - they have 12 volts power all the time, and the door switches and the headlight switch (turn full left) will ground the circuit to make the lights come on.
Bruce
Old 10-30-2010, 04:55 AM
EOD Guy's Avatar
Basicly the above posts are correct, but what no one has addressed is the amount of amps that those small switches will handle, I have used those very switches, I get them in Stainless steel, while they will handle a door lock/unlock easily enough, they didn't like the window motor high amp draw so I ended up using a relay system and the switches controlling them. BTW a headlight is made up of one switch controlling various functions (several wires) not just two wires turning on the headlights. Those switches come in several vairiations.... push ON = a momentary on when you release it, it returns home (or OFF): push- ON-ON-OFF which means... push it 1/2 way it's a monentary, keep pushing 3/4 and it latches ON, push again and it releases the latch and returns home Those ring LED have seperate contacts that controll the LED eetc.....
