Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - difference/pros/cons of spool and mini spool?
Old 03-02-2006, 01:34 AM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Wiki Edits: 9
A mini spool fits inside the standard open differential carrier replacing the spider gear assembly completely, same thing as a mini-locker like Powertrax/Lock-Rite/ or Detroit EZ-locker.
A full spool replaces the ring gear carrier and spider gear assemblies completely with a single piece.
They both do the same thing.
As you said you are going to swap out the center sections for street and strip, I will leave this thread open for discussion, the spool on the street is a no-no around here and we immediately let it be known and usually immediately close those threads too.
