a different 307 sbc build, need some advice - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-27-2010, 03:02 PM
Banned
see posts #7 and #15...
#16 isn't a bad option either.
  #17 (permalink)
Old 01-27-2010, 03:11 PM
airboat's Avatar
turbo would be cool! Sounds almost easy with Megasquirt!
  #18 (permalink)
Old 01-27-2010, 03:41 PM
lg1969's Avatar
Google "Tunnel Ram 406"
On post #16 not a bad approach. It will not cost you an arm and a leg. Turbo is great, but you need a lot of $$$
  #19 (permalink)
Old 01-27-2010, 06:11 PM
well found a steal for these so i picked up em asap
14014416...80-86...305..........1.84"/1.5" valves, 58cc chambers
whats this talk about using 1.94" valves on these? what will that do, and would a machine shop be able to do that for me? how much am i looking at? thanks for the help so far!
  #20 (permalink)
Old 01-27-2010, 06:27 PM
Banned
yes a shop can easily do that. valves will cost $80 machine work is about $200
  #21 (permalink)
Old 01-27-2010, 06:40 PM
is it worth it? what would be the benefits of upping the valve size on this engine? i keep hearing the smaller people go with things on the 307 the better, and i'd rather be saving some money if i can
  #22 (permalink)
Old 01-27-2010, 06:47 PM
Banned
porting out the heads will get you good power. larger valves help but aren't absolutely necessary. just do a good job porting, clean them up, pin your studs, swap the springs, use a thin head gasket and let er rip.
don't forget to fix your ignition too.
  #23 (permalink)
Old 01-27-2010, 07:31 PM
so are you saying the valve springs from my current heads i can use with the 305 heads? i'm trying to save as much money as i can here i got these other heads completely redone so i'd like to keep what i can from those. do you think the machine shop would help me do that or they'd rip my face off and say i need new everything for the 305 heads? and so what is the final verdict on the HEI choice? i need one thats smaller bodied due to firewall clearance.
  #24 (permalink)
Old 01-27-2010, 08:09 PM
lg1969's Avatar
Yes you can use the springs with no problem.
Get a Mallory Unilite distributer. It the same diameter as the point distributer. It will clear the firewall and get plenty of firepower.
  #25 (permalink)
Old 01-27-2010, 08:14 PM
ericnova72's Avatar
More for Less Racer
You could use all the parts out of your current heads in the 416 heads if the parts are in good shape, a good machinist will recognize this and not try to rip you off, just need to cut them for the bigger valve and do the valve job.
If you need to stay with the small cap distributor I would recommend a Pertronix Ignitor electronic conversion kit to replace the points in your current piece. These work very well and are super easy to install.
I wouldn't use a Unilite on a bet, lots of posts about this, good chance it will leave you stranded without power somewhere, someday. They are super finicky about voltage spikes in the power wires.
  #26 (permalink)
Old 01-27-2010, 08:59 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Ditto on the Unilite, every single component I've ever had with the Mallory name on it has failed or given me problems.
  #27 (permalink)
Old 01-27-2010, 10:47 PM
DoubleVision's Avatar
If you`ve never ported a head before I recommend you don`t port them other than to take the time to study pictures and learn how to do a basic bowl port / clean up. There`s not much to screw up in the bowl, but there is plenty to screw up in the main port. There is nobody that`s a natural good porter that knows where to port and how much to remove. If you don`t have a flow bench or don`t have access to one then you won`t know if porting helped or hurt you. Unless you bolt the heads on stock, get a time on the car, remove the heads, port them, bolt`em back on to see if you run quicker at the drag strip and who wants to do that? I also don`t recommend having larger 1.94 valves installed unless you have the chamber deshrouded, and after having it deshrouded is only going to raise the CC count up on the chambers. If you plan to use a thin steel shim head gasket have the heads skim milled to assure flatness, as if they aren`t flat leakage will occur. This is why basic fel pro gaskets are .041 thickness, they compensate for the head not being as flat as it could be.
  #28 (permalink)
Old 01-28-2010, 05:07 AM
ok this is pretty much my situation here i've never ported a head or anything before. So is it ok to have the 305 heads skim milled for flatness? what would that measurement be? i heard 305 heads don't like to be milled too much if at all.
  #29 (permalink)
Old 01-28-2010, 07:06 AM
Banned
Actaully the bowl is where you could screw things up, the runner is all but idiot proof, straighten it out, don't lower the floor more than absolutely necesary, try to maintain a consistent cross section.
BTW, flow benches are great for advertising! And if you know what you're doing that's about it, as they can lie!
On the bowl:
Keep your throat to 85%, don't remove more than necessary to create a smooth curve, and smooth over the short side radius.
  #30 (permalink)
Old 01-28-2010, 07:07 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'm thinking there's a basic problem- either with the timing, carb, or ?- but something in the basic tune, that's keeping the engine from performing better than it now is.
In that car, a worn out 283 ought to feel strong. A 307 w/that mild cam- even w/too low CR- 4-bbl, aftermarket intake, 4-speed, 3.90 gears, etc. should be making a better showing than it is.
mild sbc build help, cam help callmejavier Engine 20 04-16-2008 07:56 PM
MPG SBC build hillman88 Engine 33 12-12-2007 09:29 PM
350 SBC Build Help Mustangsaly Engine 25 06-14-2005 08:52 AM
SBC Advice frydz1985 Engine 8 10-10-2004 01:34 PM
Setting up an HEI on a '72 307 SBC, Need settings jpd37 Engine 3 07-13-2004 11:19 AM
