-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   Different idea for running air lines? (http://www.hotrodders.com/forum/different-idea-running-air-lines-228009.html)
HotRodMan 01-05-2013 10:05 PM
I have researched diagrams on the way to plumb your shop with air lines from the compressor. In just about every case they have a trunk line running around the perimiter of the shop or one trunk line running down the wall on one side, with your off shoots coming off the trunk line.
My question is why could I not run one trunk line down the center of the garage length ways, have my off shoots coming off of that, go over to the wall, and down to about chest height with an air filter/regulator and drain valve. The garage is 24X40 and the off shoot for painting would be at the far end of the garage, with the compressor on the opposite end. The trunk line would be slanted downward, with a 6 foot verticle pipe on the end with a drain valve.
I would have enough length for the air to cool, and it seams a lot more simple to do it this way.
Am I wrong or right?
OneMoreTime 01-05-2013 10:23 PM
Makes sense to me...
Sam
59 wagon man 01-05-2013 11:24 PM
you can do thatbut the drops should come off the top of the main to help dry the air . all lines should pitch away from the compressor with a drain on the end
Chevymon 01-06-2013 04:11 AM
Exactly correct. When your main line is on the wall you can have it low enough to pull off the top with a 6 inch nipple then loop back down, and that helps keep the water in the main line.
http://i747.photobucket.com/albums/x...psdfd049ae.jpg
