Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Different primer questions
Old 08-01-2004, 10:44 PM
MARTINSR MARTINSR is online now
You really need to get the tech sheets on the primer and it will tell you all you need to know about reducer and hardener if used.
It will also tell you the gun to use. Most any automotive gun will do the trick to some degree. However some will be much better than others.
Do you have an idea of the brand you will be using and the part number?
