Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Different rear gear ratios = ??
Old 06-23-2004, 07:06 AM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Wiki Edits: 9
The above post is only a vague response to your question, not explaining much and giving no REAL explanation.
So here goes.
Assume you have the following:
Any engine no matter the manufacturer, or size.
Any transmission, manual OR automatic with a final gear ratio of 1:1.
A tire size of 235/60/15. (This tire has a diameter of 26.1 inches)
Lets compare this information to a gear change.
gear ratio-...................3.23........4.11
engine RPM at 60 MPH-..2504........3186 (slightly above most engines' peak output, this does NOT include automatic transmission slippage factors)
top speed at 5000 RPM-..119 MPH....94 MPH (assuming engine is at peak performance at this RPM only, a lower peak WILL lower this number)
Torque at rear wheels assuming 200 foot pounds at pinion-
-.................................646'#........822' #
Changing nothing else, your vehicle will slow down with a higher ratio gear set.
