Different rear gear ratios = ??
I've seen a lot of odd explanations for different rear gear ratios and decided just to ask some experts. If I have a 3.23 gear ratio and go to a 4.11. Then I'll have less acceleration and more top end? Please let me know, these websites are confusing me. Thanks.
The above post is only a vague response to your question, not explaining much and giving no REAL explanation.
So here goes. Assume you have the following: Any engine no matter the manufacturer, or size. Any transmission, manual OR automatic with a final gear ratio of 1:1. A tire size of 235/60/15. (This tire has a diameter of 26.1 inches) Lets compare this information to a gear change. gear ratio-...................3.23........4.11 engine RPM at 60 MPH-..2504........3186 (slightly above most engines' peak output, this does NOT include automatic transmission slippage factors) top speed at 5000 RPM-..119 MPH....94 MPH (assuming engine is at peak performance at this RPM only, a lower peak WILL lower this number) Torque at rear wheels assuming 200 foot pounds at pinion- -.................................646'#........822' # Changing nothing else, your vehicle will slow down with a higher ratio gear set.
I'm actually making progress on my 1988 Suburban TH-700R4 to SM-465 transmission swap, CLICK HERE TO CHECK IT OUT. CanAm Chevelle Club 700R4 Basics 700R4 Basics W/pics ______ Last edited by M&M CUSTOM; 06-23-2004 at 06:19 AM. |
To state it another way, with the higher gear ratio (4:11) you will get to 95 mph quicker than with the lower gear ratio but... the lower gear ratio will allow you go ultimately go faster. If the engine is modified to increase it's usable RPM then top speed will be increased with the higher gears and you will get to that higher speed faster than with the lower gear ratio. It's ultimately a trade-off and the trick is to match the engine's ability to rev to the gear ratio so that your top speed and max RPM come together at the end of the quarter mile. Hope I didn't muddy the water even more... Centerline Last edited by Centerline; 06-24-2004 at 05:47 AM. |
makes perfect sense now, thanks
