-   -   Different size output shaft on c4? (http://www.hotrodders.com/forum/different-size-output-shaft-c4-87105.html)
nitrous_69stang 04-16-2006 10:38 PM
Are there different size output shafts for a c4. The reason i am asking is I just had a c4 built by GER and I have everything installed, but when I went to put the drive line on it would not slide over the splines of the output shaft. I know there are different input shaft spline counts for different years but i have never heard of different size/spline for the output shafts.
xntrik 04-17-2006 12:45 AM
Ford guy here. Obviously there is if your old yoke won't go over the new shaft. Finding another yoke and changing it should be easy and not too expensive and probably will not alter drive shaft length. Higher performance trans gets a bigger shaft.... logical to me.
Just guessing but earlier C-4s were for 289/302s. Later ones got into 351 Ws so they might be larger.
I don't exactly know for sure, but I am going to find out just for curiousity sake.
polkat 04-17-2006 01:02 AM
There are different lengths. The truck C4 has an output shaft about 6" or 7" shorter then the car C4's, and yokes for the truck C4 are bolt-on and may indeed be a different spline setup. Was your vehicle originally running a C4? If it was running a manual 3 speed, it won't fit.
nitrous_69stang 04-17-2006 11:51 AM
Yes its a 69 mustang that had a c4 just upgrading for performance sake.
