Different size output shaft on c4? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2006, 09:38 PM
Are there different size output shafts for a c4. The reason i am asking is I just had a c4 built by GER and I have everything installed, but when I went to put the drive line on it would not slide over the splines of the output shaft. I know there are different input shaft spline counts for different years but i have never heard of different size/spline for the output shafts.
Old 04-16-2006, 11:45 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Ford guy here. Obviously there is if your old yoke won't go over the new shaft. Finding another yoke and changing it should be easy and not too expensive and probably will not alter drive shaft length. Higher performance trans gets a bigger shaft.... logical to me.
Just guessing but earlier C-4s were for 289/302s. Later ones got into 351 Ws so they might be larger.
I don't exactly know for sure, but I am going to find out just for curiousity sake.
Old 04-17-2006, 12:02 AM
There are different lengths. The truck C4 has an output shaft about 6" or 7" shorter then the car C4's, and yokes for the truck C4 are bolt-on and may indeed be a different spline setup. Was your vehicle originally running a C4? If it was running a manual 3 speed, it won't fit.
Old 04-17-2006, 10:51 AM
Yes its a 69 mustang that had a c4 just upgrading for performance sake.
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
Borg-Warner R10 Overdrives? packratwrecker Transmission - Rearend 38 12-27-2005 08:44 AM
Tranny swap, What size tail shaft? Ralph Horak Transmission - Rearend 2 01-12-2003 05:35 PM
front drive shaft in bronco 2 steve norman Transmission - Rearend 2 10-19-2002 11:11 AM
output shaft to slip yoke vader Transmission - Rearend 1 03-28-2002 09:31 PM
