Differential Cleaning. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2012, 09:17 AM
Bryans36's Avatar
Hello. I Just Took Apart My 9 inch Rear End And Some Epople Are Saying Not To Put The Differential In The Parts Cleaner And Other Are Saying It Will Be Ok,, Does Anyone Know If It Will Hurt Anything Or Not?
Old 08-18-2012, 09:44 AM
Crosley's Avatar
Wiki Edits: 1659
If you use a petroleum based cleaner you will be fine. A water based cleaner is not advised
The Following User Says Thank You to Crosley For This Useful Post:
Bryans36 (08-18-2012)
Old 08-18-2012, 11:50 AM
big gear head's Avatar
High Performance Rear Ends
Mineral spirits and other degreasers work fine and there is nothing that it will hurt. Just be sure to get it completely dry before putting it back in the housing.
The Following User Says Thank You to big gear head For This Useful Post:
Old 08-20-2012, 10:38 AM
I've always used brake cleaner. Never had a problem.
Old 08-20-2012, 11:24 AM
Irelands child's Avatar
Unless I was to replace bearings and seals, I would not immerse that chunk in a parts cleaner vat. Just for confirmation of what's in there, get a clean glass container, dip out some of that liquid and just let it sit for a hour or so - probably be a bunch of crud precipitate out and lie on the bottom of that container. Next. reach all the way down, and if necessary due to some being pretty nasty, wear some rubber gloves - what ever is on the bottom of that vat - that's some of what will be in those nice shiny bearings - and there are at least four which can get expensive in East Overshoe on a Saturday afternoon.
Unless there is a real good reason to dunk that differential, don't - you can do a good cleaning with a bunch of rags and some spray degreaser along with a half hour of your time.
The Following User Says Thank You to Irelands child For This Useful Post:
Bryans36 (08-20-2012)
7.5 differential warrick0209 Transmission - Rearend 4 10-06-2010 10:36 PM
my differential tootiebeish Transmission - Rearend 4 08-26-2008 07:15 PM
Differential itsmepsa Transmission - Rearend 2 07-24-2003 09:42 AM
GM Differential I.D. megmar Transmission - Rearend 0 07-09-2002 05:16 PM
Used Differential bigjoedo Transmission - Rearend 2 02-26-2002 12:02 AM
