Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Differential Decoding?
Old 04-08-2010, 04:44 PM
matt167 matt167 is offline
Wiki Edits: 31
depending on the axle, it might have the ratio stamped into 1 of the axle tubes.. beyond that, you can open up the rear and count the gears... axle code is on a information tag in the glove box or on the door. but then if the rear has been changed, you don't know what it is w/o checking
