Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Differential Decoding?
Old 04-08-2010, 05:32 PM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
If this is an older GM rear end then there will be a code stamped into the right axle tube on the front side close to the center. If it's a Camaro rear end then go to a Camaro web sight and check the codes. If it's a Chevelle rear end then do the same on a Chevelle web sight. This code will tell you what the original gears were and what differential it had, but that might not be what is in it now.
