Differential Decoding Help? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2012, 07:48 PM
Hello! I was hoping someone could help me decode the stamping marks on my differential. It's been painted over, and the original metal tag (if there was one) is gone, so this is all I have:
I THINK this is what they say, feel free to correct!
DIF 41
4868A
C5??
3417
Here are the links to some pics if they help too:
http://i1255.photobucket.com/albums/...ps6460eb57.jpg
http://i1255.photobucket.com/albums/...ps4ccee0bd.jpg
http://i1255.photobucket.com/albums/...pse0946760.jpg
Thanks for any help you can offer me! Just bought the car and trying to figure out what everything is
Old 10-04-2012, 04:26 AM
SSedan64's Avatar
Those are Casting Numbers & Dates. They wont tell you the gear ratio.
It looks like a 9" inch Ford to me.
For ratio Info, you'll have to count the Pinion & Ring gear teeth & divide Ring by Pinion teeth #.
Can also rotate the tires 1 revolution & count the Driveshaft revolutions if Posi Diff. If Open Diff rotate 1 tire 2 revolutions & count DS revs.
Tag codes >> Ford Rear Axle Assembly Identification - Page 01 - FORDification.com
Other IDs >> http://www.maliburacing.com/ford_9_i..._nine_inch.htm
Old 10-04-2012, 07:42 AM
For my own curiosity, whats this in anyway?
Old 10-05-2012, 07:28 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Links to info on ID'ing the rearend can be found here. Good luck.
9 inch, differential, ford, rear end
Need help decoding Alvin Livers Engine 3 02-20-2011 04:43 PM
decoding a t-10 1970amx Transmission - Rearend 4 04-28-2010 11:35 AM
Differential Decoding? unstable Transmission - Rearend 3 04-08-2010 06:17 PM
vin # decoding D-MAN Hotrodders' Lounge 3 11-04-2008 04:31 PM
decoding ID tag for 9" Ford differential green15350 Transmission - Rearend 2 08-14-2006 11:59 AM
