Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Differential Gear Calculations
Old 04-02-2009, 07:25 PM
dedub dedub is offline
80 SS El Camino
If the TH-400 is like the TH-350 which I'm assuming they are, then it should slip right on. Have you taken off the old one? There is a removable clip that is easily removed with a small screwdriver. Once the clip is removed, very light taps with a rubber mallet/screwdriver should back off the old one. Careful not to damage the shaft, slip the new one on in the same method. Again, careful of the shaft and don't tap it in too far, it is possible. Slide your clip in the original location and button it up.
