Differential Gear Calculations - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2009, 03:34 PM
Last journal entry: 1965/66 Impala body lines.
I should be able to figure this out and it's most likely been hammered to death on this site, but, what is the equation to figure out what gears you need to correct your speedometer? OK, rear differential gears. I have a 65 Impala SS that came factory with a 6/three-on-the-tree. Since then it's been upgraded (?) to a 350/Saginaw 4 speed. Now I'm going to a 396 (correct block #) and a TH400. But I think none of that matters. It has 3:21(?) gears in it now and the speedometer is WAY off.(slow) It has a 10 bolt rear that I'm considering rebuilding with new axles and HD ring and pinion (Richmond) and I would like to know how to figure out what gears to use for correct speedometer readings. This will be for street use only, so I'm pretty sure the 10 bolt will be tough enough.
Old 03-11-2009, 05:34 PM
fast68's Avatar
likes chevy trucks & boobies
howdy there,
the 10 bolt will be fine unless youre gonna big block it an constantly hard race it with slicks on pavement or something else crazy, or if it already has a problem such as worn bearing or gears, loose pinion nut, etc.
there are lots of speedo gear ratio calculators on the internet and on billions of internet auto forums.,
do a google and you will find pages of them
or jut swap the speedo gears from the 3 speed onto your 400
to check for accuracy take it on the freeway and while driving 60mph exaclty, use a stop watch to time yourself between two concurrent mile posts
if you get to the next post before 60 seconds then youre going faster than 60mph and you need to slow the speedo down by putting in a larger driven gear, or a smaller drive gear
get to the post later than 60 seconds then you need the opposite thing.
hope i dont have that backwards
good luck
Old 03-11-2009, 06:12 PM
Cape Cod Bob's Avatar
Check out this site
http://www.transmissioncenter.net/sp...____va.htm#350
Old 03-15-2009, 10:48 AM
Still confused
OK, those are great sites, BUT, I have a large 44 tooth driven gear with a 7 tooth driver. Are all gears interchangable as long as they are for the correct transmission? Is it a game of switching grear till you hit it right?
Old 03-15-2009, 12:51 PM
Here's a calclulator:
http://www.bgsoflex.com/speedo1.html
Old 03-15-2009, 09:26 PM
http://novaresource.org/speedo.htm
http://novaresource.org/speedo2.htm
Old 04-02-2009, 03:28 PM
WOW Jim. That site really helped. I ordered my new gear and it arrived today. Oh man! it's a steel gear and mine is plastic. I called PACT and they assured me it was correct and that plastic TH400 gears haven't been made in over 30 years. So How do I get this sucker on my output shaft? Should I heat it as I do harmonic balancers or just use the BFH method?
Old 04-02-2009, 07:25 PM
80 SS El Camino
If the TH-400 is like the TH-350 which I'm assuming they are, then it should slip right on. Have you taken off the old one? There is a removable clip that is easily removed with a small screwdriver. Once the clip is removed, very light taps with a rubber mallet/screwdriver should back off the old one. Careful not to damage the shaft, slip the new one on in the same method. Again, careful of the shaft and don't tap it in too far, it is possible. Slide your clip in the original location and button it up.
GEar DRIVE QUESTION! Werird Noise! boneyard Buick Engine 7 02-14-2008 04:45 PM
Gear Drive to Timing Cover Clearance Double_v23 Engine 5 01-11-2008 11:08 AM
Gear Drive to Timing Cover Clearance Double_v23 Engine 7 01-10-2008 07:12 AM
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 01:01 PM
Speedometer Gear Change ? bigjoedo Transmission - Rearend 3 07-04-2002 06:52 PM
