Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Differential noise after warming up?
Old 07-07-2004, 10:30 AM
blndweasel's Avatar
blndweasel blndweasel is offline
paints everything flat black
Last journal entry: September 2005 - Current
One thing that I can contribute, not sure of how much use it will be to you, but when I had some chatter in my posi unit a few years back, all it took was some GM differential additive to quiet things down. It's a cheap solution so I always try that first when I get noise in the rear end that sounds like it could be simply due to friction.
good luck
