Difficult to turn at an idle. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2010, 06:46 PM
bigdog7373's Avatar
Of course it's fast
When i'm driving slow and the engine is close to idle speed, maybe a couple hundred rpms higher, it gets quite difficult to turn the car. It's not a constant difficulty though, it kinda goes a little at a time. Does anyone know what would cause this?
Old 12-30-2010, 06:47 PM
bigdog7373's Avatar
Of course it's fast
Btw, it's a 78 firebird with a chevy 350.
Old 12-30-2010, 06:53 PM
Localboy808's Avatar
I'm guessing you checked the fluid? Other than that a bad pump?
Old 12-30-2010, 06:57 PM
bigdog7373's Avatar
Of course it's fast
The fluid level is fine. So it's gotta be the pump i guess?
Old 12-30-2010, 07:03 PM
That would be my guess. Is it a very old pump? Good thing they are not that expensive. Easy thing to try I guess. The belt isn't slipping is it? Im sure you would hear it.
Old 12-30-2010, 07:12 PM
bigdog7373's Avatar
Of course it's fast
Yup, i'm pretty sure it's original from 78. Well i guess i'll add that to my lift of crap that's wrong with the car. I'm gonna need another sheet of paper soon!
Old 12-30-2010, 07:15 PM
ericnova72's Avatar
More for Less Racer
Pulley ratio between crank and pump isn't turning pump fast enough. You may need to put a larger crank pulley on the engine. Make sure belt isn't slipping also.
You could just turn up the idle speed a bit, below 850 rpm tends to cause this problem if crank pulley is only 6-1/2" to 7" diameter.
If it was originally a Pontiac engined car the Pontiac engine has a larger diameter crank pulley.
Old 12-30-2010, 07:18 PM
bigdog7373's Avatar
Of course it's fast
It has a smaller crank pulley that the original 305 that was in the car. I tried making it idle faster today. It was idling at 950rpm in gear and still did it. I guess the pump is finally shot after 32 years.
Old 12-30-2010, 07:25 PM
At least you can drive it! I got my elky with no engine or trans. Plus it was sitting for maybe 20 years. My list is longer! Let us know what the fix was.
Old 12-30-2010, 07:30 PM
bigdog7373's Avatar
Of course it's fast
Yea i don't think i'll be fixing it though. I'm trying to sell it right now. I guess i'll just lower the price again.
Old 12-30-2010, 07:59 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 Eric Or a pump going south on you. JMO
Cole
How difficult would it be my oldcar Hotrodding Basics 3 01-08-2010 11:02 AM
How difficult is it to set up a powerglide? Quarter Flash Transmission - Rearend 2 06-04-2007 05:48 PM
How difficult?? BigTex88 Transmission - Rearend 3 03-08-2006 07:08 PM
Not that difficult '69 RS Introduce Yourself 1 10-16-2004 03:21 AM
Really difficult problems, please help AnthonyM Engine 47 03-02-2004 11:44 AM
