Dim dash lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2012, 11:00 AM
Dim dash lights
Hello I am sure this has been discussed before but I was wondering if. . .
I have a bit of an issue with the brightness of my original 5 in 1 dash gauge in my '49 ford coupe.
The wire is hooked up to the light switch in the location it meant for (says dash under the terminal). The wire that houses the lights is in series with no ground wire. I am assuming that the bulb housing is what grounds the circuit. When I first bought the car the dash lights were not working at all. I looked at the gauge from behind the dash and saw one bulb housing was out of the area it should be clipped into. So I took all the housings out of the clips and found one bulb that was broken. I replaced all the bulbs with brand new ones clipped them into the gauge as they should be and I had some very very very dim light. So dim I had to have pitch black to even see that there was some lighting in the gauge. It seems to be all 5 lights that are not working as they should. The only part to my 5 in 1 gauge that is hooked up is the Speedometer which I hooked up just last weekend.
I am guessing that this dim light issue is not normal.
Any suggestions?
Old 10-20-2012, 04:01 PM
302 Z28's Avatar
Try to temporarily attach a ground wire and see if it improves.
Vince
Old 10-20-2012, 04:36 PM
The trouble I was having was with the coloured caps that are a part of the original gauge. They look like they are a thick black light glass that over time has darkened. I could either get new ones that are not so dark and switch them, or I could take them out and put coloured bulbs in. case closed!
Old 10-20-2012, 04:54 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You may have dimmer bulbs, there are 2 candlepower bulbs like #1893 that fit the same as the 3 cp #1816 bulb. There may even be a 1 cp bulb that fits the same, but not sure.
Old 10-20-2012, 05:06 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Old 10-21-2012, 12:19 AM
Is the wiring original? Sounds a little crazy, but if 1 broken bulb prevented all the bulbs from working, maybe it's wired in series? Would explain the dim lights as each bulb would getting less than 2 volts.
Old 10-21-2012, 09:10 AM
I fixed the issue.
it was the old purple-ish black light bulb covers that had darkened over time to the point where hardly any light was able to pass through at all. I removed them and presto. . . too much light now lol
Old 10-21-2012, 12:31 PM
Yeah, I saw that after I posted. Thought I deleted my post.
Dim dash lights dmonson83 Electrical 7 10-20-2012 05:01 PM
accessory lights dim when head lights turned on 36int Electrical 8 04-10-2011 11:59 AM
1985 Dim Lights on Dash BillH 85 Electrical 3 09-07-2010 06:20 PM
No lights on dim lanierledford Electrical 5 09-29-2006 05:37 PM
Dim Dash lights Torino1 Electrical 2 01-14-2006 05:36 AM
