Dim head lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2008, 11:19 AM
CrashFarmer2's Avatar
Dried up in the Drought! :(
Last wiki edit: Pre-1980 VIN decoding
Last journal entry: 1978 Chevy pickup battery tray repair
Wiki Edits: 409
Dim head lights
My 1994 Lincoln Mark VIII has extremely dim head lights. On low beam it is like you have two candles lighting your way. The high beams seem to be about what the low beams should be.
I bought a high intensity blue ice bulb yesterday and stuck it in last night and it didn't seem to change the light output at all.
I just bought this car Saturday and so far I love it except it is not real safe after dark.
Old 03-05-2008, 12:07 PM
302 Z28's Avatar
First thing to do is make sure the lights have a good ground. If that does not improve them consider running them off relays. Take a look at this thread for info on how to do this.
Vince
Old 03-05-2008, 12:56 PM
malc's Avatar
Born To Be Mild
This is how MadElectrical describes the problem.
Old 03-05-2008, 02:38 PM
T-bucket23's Avatar
Wiki Edits: 26
if everthing is stock, you most likely have a bad ground. it is real easy to check. Turn on the lights, ground 1 probe of your multimeter to teh negative battery terminal and the other probe to the low or high beam feed at the light. If it looks good (over 13v or so with car running) remove teh lead from th battery and connect it to the ground pin on the lamp or the radiator support and see what the reading is there, if it is bad then you definatly have a ground issue. If the first test yeilds poor readings themn your feed somewhere is no good.
90% or the time this is due to a car being hit and a poor job of putting everything back together. grounds omited or connected to plastic, I have seen just about everything
should be an easy fix
good Luck
Having problems with the tail lights... HammerGVette Electrical 3 04-17-2007 01:06 AM
Head lights kilrshrk Electrical 3 04-16-2007 09:45 PM
head lights ChevyGrrrl16 Electrical 8 02-15-2007 12:04 AM
cylinder head cracked?!?!?!?! Blob Engine 4 01-24-2005 06:12 PM
frenching head lights rot_n_rollzombie56 Body - Exterior 4 02-25-2003 04:31 PM
