30 Ford coupe body demensions: Width of body at rear..44 inches. Width of body at widest point ....51 inches. Width of body at cowl or firewall area ...34 inches. Height after my 4 in. chop....44 in. Length from front of grill shell to rear is ...120 inches.
These are some measurements I tried to take off of mine.2inch chop ,,,I wouldn't say they are accurate.
Another way to get fairly accurate measurements for ANY portion of a model A body (or others as well) is to buy a plastic model (Revelle etc) and then use your calipers or a very precise rule to get the measurements...then just multiply by whatever the scale the model maker used (usually 1/24 or 1/25). I used this method for the Rat on a Shoestring project and it worked pretty slick.
Dewey
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
Brian,
If I were attempting an "exact" replica I would have to agree with you that only a full size original would do for getting the correct measurements. But for determining relative proportions, fitment for various frame/chassis options, and for homebuilt projects like the Rat on a Shoestring, I think the plastic model method can be quite helpful. Like everything else, it's just another tool in the box and it may not be suitable for every project. Dewey
| the best way to channel 1930 ford coupe | sanderso | Body - Exterior | 1 | 07-01-2005 08:23 AM |
| 37 Ford Coupe Dimensions | MARCELO URUGUAY | Body - Exterior | 4 | 12-14-2004 08:29 PM |
| 1930 Coupe Doors? | SuperFrog | Body - Exterior | 3 | 03-06-2004 04:53 AM |
| gas tanks for 1930 ford 5-window coupe | bettylew | Body - Exterior | 5 | 01-13-2003 04:46 PM |
| window measurements for 30 model a coupe | tumbles | Interior | 9 | 09-19-2002 09:42 AM |
