Dimensions of disc brake rotors - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2008, 10:05 AM
Does anyone know of a catalog, chart, or listings of dimensions for replacement disc brake rotors? Rather than go the route of rotor hats and rotors, would like to find some cast rotors close to the dimensions I need, and then make caliper adapters to fit.
Would be looking for rotor OD, rotor thickness, and offset or a relative dimension from the hub mounting face.
Thanks in advance.
Old 09-25-2008, 10:23 AM
powerrodsmike's Avatar
Wiki Edits: 161
I have a copy of a Raybestos master reference guide , and it shows all of those dimensions and the rotors are listed by part number, instead of application.
I got,(finagled ),my copy from my local brake parts supplier,(wholesale house, supplying to stores and shops), you may find that your local old school auto parts store has a copy in the basement somewhere..Brng them some coffee and donuts and they may let you sit at the end of the counter with it for a while.
I have attempted to go that route with building a brake system,, and found that getting hats and rotors saves a ton of time.
Coleman racing as well as wilwood has some cast rotors that are listed by dimension also, and you can buy their hats to make pretty much any offset or bolt pattern you need.
The Coleman racing stuff is priced better than the wilwood stuff.
Later, mikey
BE different....ACT normal.
1964 F100 Disc Brake Conversion Charlse P. Green Suspension - Brakes - Steering 5 01-14-2007 09:09 PM
64 el-camino disc brake swap dusterbd Suspension - Brakes - Steering 10 12-16-2006 01:01 PM
"Orphan" '54 disc brake conversion. . . FiddyFour Customline Suspension - Brakes - Steering 2 11-12-2004 08:48 AM
79 LTD disc Brake rearend Mike Pomerantz Suspension - Brakes - Steering 2 09-11-2003 11:19 AM
will these disc brake spindles fit my Torino? jchris64 Suspension - Brakes - Steering 2 09-07-2003 05:20 AM
