Dimmer switch wired wrong? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2008, 07:24 AM
jvgrago's Avatar
I just replaced my original dash unit from my '72 Chevy Nova with a Nordskog digital dash. It works awesome (and thanks for all the help I received here). But I have had a problem (even with my old dash) that when the highbeams or off the highbeam indicator light is on and when the highbeams are on, the indicator light is off. I am not sure where to look for this issue but maybe the wires at the dimmer switch? I have placed my wiring diagram here:
http://www.vorshe.com/Wiring.pdf
Any ideas?
Thanks
Jim
Old 06-10-2008, 07:43 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
The hi-beam indicator gets it's power from the dimmer switch.
I would venture to guess that someone had dome some wiring in the past.
The Dimmer should have a blue (feed from HL switch) a tan(low), green(hi)
It appears from your diagram that the take off for the indicator is on the bulkhead disconnect.
Will be a lt green wire,
I would look for crossed wires on the engine side of the bulkhead.
then check the prober orientation of the wires in the cabin side.
Somewhere----the indicator wire had been tapped into the low beams, instead of the hi beam.
if you have upgraded the headlight wiring, perhaps you got the wires mixed up at the relays----Quick fix for this would be to swap the relay coil feeds.
Old 03-05-2014, 12:17 PM
jvgrago's Avatar
Hey sorry I didn't realize the wiring.pdf file was not working. I have the correct link here:
http://www.vorshe.com/Wiring.html
Old 03-05-2014, 04:36 PM
EOD Guy's Avatar
digital dash should have a input for the hi beam indicator..... not positive but you should have a lt green wire that is the hi-beam feed, behind the dash panel, that's tied into the dimmer switch etc..... as mentioned above it's probably switched/crossed
95 Camaro fan switch problem / ignition key problem human_forklift Electrical 12 05-29-2015 07:57 PM
Ignition switch config coupe66 Electrical 9 01-07-2008 06:47 PM
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Clutch safety switch wavy Electrical 4 04-27-2007 08:59 PM
Dimmer switch grommet 5window Interior 6 05-27-2004 07:46 AM
