ding ding - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2007, 01:11 AM
ding ding
i had a new steering column put on my cutlass and now when i turn on my head lights i hear a ding ding sound, also when i press the brake pedal the yellow park lights come on. can somebody tell me what is going on?
Old 07-08-2007, 01:22 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Off hand, I'd say the Park lamps were wired into the turn/Brake system in error, and now react with those circuits..most likely culprit is the plug at the bottom of the column..check for a mis~wire..the park lamps (front) Traditionally go to a terminal on the light switch..not the rear lamp harness.
The Ding~Ding, may be the headlight on chime which should shut off with the ignition switch in the on position. Check to see the chime timer isn't wired to a "Hot at all times " power source..If it is move it to "Hot in Run Only" and it will work.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
ding stopper stinkydidit Body - Exterior 2 01-16-2006 10:21 AM
Ding PrimaDude Body - Exterior 3 12-01-2002 11:36 PM
Ding dong the witch is dead! HemmiGremmie Hotrodders' Lounge 6 10-31-2002 12:21 PM
