Dip stick - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2007, 12:17 AM
Dip stick
I recently bought a early 1970's Chevy 350. The engine came out of a 1968 Chevelle and was a running engine when I bought it. When I picked it up the seller explained he broke off the oil dip stick when removing from the car. It is broke off even with the block. Any ideas besides drilling it out? thanks
Old 04-03-2007, 12:22 AM
re:Dip stick
You could try a BIG sheet-metal screw and a dent puller... Not the most subtle approach but I've used it in similar situations.
RB
Old 04-03-2007, 06:07 AM
drop the pan and tap it out from the inside..then reseal the pan.
Old 04-03-2007, 08:24 AM
I'll second the sheet metal screw and slide hammer approach. I've used this successfully on several broken dipsticks, including a couple where the engine was still in the car. It doesn't hurt to try that first and THEN drop the pan if it doesn't work.
Old 04-03-2007, 11:53 AM
DeathRattle's Avatar
Some Punk Kid
If the engine is out take the oil pan off and tap it out. I had to do that with my 1970 small block. Must be a broken dipstick tube epidemic.
Old 04-03-2007, 07:23 PM
Find a screw or bolt that will thread into it a little ways, then find an open-end wrench that barely fits around the bolt shaft. Use a small hammer or something to tap the wrench upward against the head.
SBC Dip Stick Sleeve Removal Houston54 Engine 4 09-26-2006 06:35 PM
Dip Stick Reading 70bird Engine 10 06-08-2006 11:21 PM
69 428 Pontiac dip stick dgcantrellsr Engine 3 05-27-2006 12:22 PM
Tranny dip stick tube gilby246 Transmission - Rearend 2 05-11-2005 01:07 PM
oil spits out dip stick and breather dosch13@aol.com Engine 5 12-11-2003 05:27 PM
