dip/stick oring still leaks. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2013, 10:47 PM
Cannot seem to get it right ! Just ordered another and to get it Thurs . One more try and maybe time for a cork LOL !
Old 08-06-2013, 07:40 AM
Irelands child's Avatar
After two leaky Lokar transmission dipsticks, a single O ring and a double O ring version supplied by them under warranty, I ended up with a Hughes - no longer leaking (at least there) . Lokar IMO, makes mostly good products, just lousy transmission dipsticks
Irelands child
The Following User Says Thank You to Irelands child For This Useful Post:
f/bird (08-10-2013)
Old 08-06-2013, 02:05 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
What I've done with Lokar unit, i machined it so the end fits a slip boot design seal
The Following User Says Thank You to Crosley For This Useful Post:
f/bird (08-10-2013)
Old 08-09-2013, 11:21 AM
Not sure if the bracket would let the tube go all the way in to seat properly ? Any pics around of a trans out of car or in to see the proper setting ? As it was there was a slight space 1/8 in. or less between flange and trans casting . I'm not sure if it was going down in to let oring seat ? Any thoughts?Thanks!
Old 08-09-2013, 11:56 AM
sedanbob's Avatar
I used a Lokar dipstick on my 700-R4, put a little silicone around the o-ring, no leaks. Mine is a bellhousing mount - maybe the firewall mount ones leak because of flexing as the engine torques? I guess I will find out, as I will be changing mine to a firewall mount soon - dipstick handle is too close to the exhaust header to check the level without heavy gloves (or the smell of burning knuckles).
The Following User Says Thank You to sedanbob For This Useful Post:
f/bird (08-10-2013)
Old 08-09-2013, 11:59 AM
This is with the Hughes dipstick in a Ford C4 mentioned above. Yours really needs to be down to the bulge - even this one leaked until I snugged it down and then added the bracket to keep it from wobbling around.
Irelands child
f/bird (08-09-2013)
Old 08-10-2013, 09:55 PM
I think I got it this time !!! One more oring and some rtv around the flared area and after putting it back in I tapped the bracket down from the top with a large s/driver and let it set overnight . It looked like the little tap mushroomed the rtv some for an added seal . So far so good . Next challenge is the shift rod seal , It has a minor drip . Thanks all for your input !!
dip stick question??? tinman386 Engine 3 06-07-2007 08:23 PM
Dip stick wfd102 Hotrodding Basics 5 04-03-2007 08:23 PM
Dip Stick Reading 70bird Engine 10 06-09-2006 12:21 AM
driverside dip stick REZ_DEVIL Engine 3 10-22-2005 06:27 PM
dip stick 71chevelle406 Engine 3 12-07-2003 12:58 PM
