-   -   dip stick question??? (http://www.hotrodders.com/forum/dip-stick-question-117627.html)
tinman386 06-07-2007 09:12 AM
I asked this question in the basic forum and i havent recieved must response so i hope no one minds that i repost it here . This is perhaps where i should've p[osted it to start with.
I want to install my new chrome oil dip stick in my sbc. My question is that it seems to be a fairly tight fit ( doesnt just slide in) im guessing this is the way its supposed to be. So how do i install it? do i put a box wrench on it and tap it in? I just dont want to have issues once its in so i thought i would ask a dumb question instead. :confused:
boatbob2 06-07-2007 09:23 AM
dip stick
hi,on the dipstick there is a collar,about 2 in from end (bottom of dipstick) put a SMALL amount of silicon on bottom of collar,take a piece of wood, put on top of dipstick, line up dipstick and hole,and tap wood with a hammer. if it doesnt go in tap it HARDER.
BogiesAnnex1 06-07-2007 12:21 PM
The problem you're having is that the chrome builds some thickness to an already tight fit. There is a bulge where the dip stick sits down on the block. Remove the chrome below that point. Add a little Lock-tite and press the tube in.
Bogie
DHMag 06-07-2007 07:23 PM
i just chamfered the end of the tube, smeared a bit of moly on it, and pushed it in.
