Dipstick Has Fallen Into Tube - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2010, 01:48 PM
I had gotten my oil changed at a Jiffy Lube about a month ago. Today, I decided to just check the oil level just to make sure everything was set.
Well, when I pulled out the dipstick, only the handle came up. The dipstick itself was still inside the tube.
I am wondering how I can get it out? Part of the handle is in there, too, so it's sort of lodged. Is there any way I can retrieve it without having to replace my tube?
Thank you very much for any help on this, it is greatly appreciated.
Old 07-27-2010, 02:06 PM
27 t's Avatar
WHO WHAT ME WAIT I DON'T KNOW.
Last journal entry: Door skins removed
i'v had this happen before if its a plastic Handel you can try drilling a small hole in it. installing a small screw in and gently pull out the stick....
Old 07-27-2010, 02:19 PM
hemi joe's Avatar
loves ex cop cars
what type of car do you have?if it's a chevy unbolt the tube from the block and pull out the whole tube out of pan.
Old 07-27-2010, 02:21 PM
Hi
I have a Nissan Sentra 2002. I could drill a hole, but wouldn't installing a screw push the stick down further?
Also, what do you think of this idea: I have some Window Caulk. Could I dab a little on the end of a nail or screwdriver and lightly press it against the top of the fallen stick, wait a little bit, then lift it up?
Any help is great, thanks!
Old 07-27-2010, 03:30 PM
27 t's Avatar
yes it could go down more.. you could try the caulk i't could work only one way to find out dab it.....
Old 07-27-2010, 03:55 PM
hemi joe's Avatar
loves ex cop cars
why not try a very thin magnet,just a thought.
Old 07-27-2010, 03:58 PM
jstuhl's Avatar
magnet
yes, a magnet was my first thought. My second thought was, note to self: change my own oil.
Old 07-27-2010, 04:00 PM
bigdog7373's Avatar
Of course it's fast
just pull the tube out of the block.
Old 07-27-2010, 04:08 PM
geezer69's Avatar
Die standin' up
Last journal entry: geezer69 nova 63
yep, big dog. your rite. it wont take but a minute.
Old 07-27-2010, 04:23 PM
hemi joe's Avatar
loves ex cop cars
that is a great thought.
Old 07-27-2010, 04:42 PM
SSedan64's Avatar
Remember this? LOL! >> http://www.youtube.com/watch?v=wiCAJ8ULnaI
Old 07-27-2010, 05:09 PM
Thanks everyone
I actually used the vacuum trick. It worked perfectly; no mess. I don't know if a magnet would have worked because part of the handle was in the tube and it's plastic.
On a separate note: How much does a dipstick cost?
Thanks!
Old 07-28-2010, 07:48 AM
bigdog7373's Avatar
Of course it's fast
I really can't tell if your agreeing with me or you're being sarcastic.
Old 07-28-2010, 12:50 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
A trick I usually use for broken plastic dipsticks is to heat up a drywall screw to nearly glowing, holding it with a pair of Vise-grips, then gently screw it into the plastic while it's still hot, let it cool a few minutes, then pull it out. Works every time,
Old 07-29-2010, 09:41 AM
55effie's Avatar
Amen. Never had good experiences with those fast oil change places.
92 sbc dipstick tube Eric64 Engine 1 05-10-2009 03:14 PM
How I got the dipstick tube out. user151 Engine 5 03-17-2009 08:30 AM
Dipstick Tube Extraction -- SBC PatM Garage - Tools 5 03-28-2006 07:37 AM
Dipstick Tube Extraction, SBC PatM Engine 10 03-27-2006 10:49 AM
broken oil dipstick tube guilty1 Engine 10 01-16-2003 03:17 PM
