direct clutch pressure plate - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2007, 10:30 AM
runn141's Avatar
will the direct clutch pressure plate from a 700r4 interchange with a 350 turbo?
Old 12-02-2007, 01:12 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
no , not the same
Old 12-02-2007, 03:59 PM
runn141's Avatar
reason i ask, i seen it on musclecar tv
Old 12-02-2007, 05:19 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I've seen many mistakes on that TV show. Same with magazines.
Torque specs for pressure plate? HotRodMan Engine 3 09-21-2006 10:15 PM
Clutch on and off FirebirdFitzpatrick Transmission - Rearend 2 02-19-2005 11:43 PM
th350 FWD clutch cushion plate th350mark Transmission - Rearend 3 12-13-2002 12:38 PM
new clutch, used pressure plate? chevyelc81 Transmission - Rearend 11 10-16-2002 04:14 PM
clutch linkage!!? chevyelc81 Transmission - Rearend 11 08-01-2002 06:46 AM
