Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Direct Drive Gears.
Old 09-13-2010, 09:12 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Originally Posted by afsog
Have set of Direct Drive Pete Jackson Gears. Have 400 SBC with Solid Lifters. Is there any truth in the following. "If you have solid Lifters, you cannot or should not install Direct Gear Drive". May damage lifters.?? I hAVE NEVER HEARD THIS BEFORE. I AM THROWING THIS OUT THERE in hopes I find someone with expertise .APPRECIATE YOUR ADVICE. THANKS.
Where did you here this?? No truth to it.
The dual idler gear drives(Pete Jackson is just one brand) are a less than desirable part to use from any good engine builders standpoint, but solid lifters have nothing to do with it.
