Direct Drive Gears. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2010, 06:07 PM
Direct Drive Gears.
Have set of Direct Drive Pete Jackson Gears. Have 400 SBC with Solid Lifters. Is there any truth in the following. "If you have solid Lifters, you cannot or should not install Direct Gear Drive". May damage lifters.?? I hAVE NEVER HEARD THIS BEFORE. I AM THROWING THIS OUT THERE in hopes I find someone with expertise .APPRECIATE YOUR ADVICE. THANKS.
Old 09-13-2010, 08:12 PM
ericnova72's Avatar
More for Less Racer
Where did you here this?? No truth to it.
The dual idler gear drives(Pete Jackson is just one brand) are a less than desirable part to use from any good engine builders standpoint, but solid lifters have nothing to do with it.
Old 09-14-2010, 02:00 PM
Gears
[ Thank You. I too see no reason why not to istall. Just not familiar with Solid Lifters since I had a 57 Ford 2 dr with Solids. Thanks Again. AFSOG.
Old 09-14-2010, 02:01 PM
Gears
Conversation took plasce during a Car show with one to many Beers. Thanks for your input.
Old 09-14-2010, 03:08 PM
techinspector1's Avatar
Wiki Edits: 326
This line of thinking may have been generated from the idea that gear drives will set up harmonics which are harmful to the valvetrain. Apparently, this has sound engineering basics, although I have never personally read of or talked to anyone who has experienced problems related to gear drives.
Some of these things get twisted around by the passing of information from one human to another. If you sit 10 people down in a row, whisper any statement to the first one and have the message be passed from one person to the other by whispering between them, the statement will be completely different when it gets to the 10th person.
So it is with the passing of technical information from one person to another. For instance, engineering techs at Blower Drive Service will tell us that a blower motor will operate best on gasoline using a camshaft with a LSA of 110 degrees and that the same motor on alcohol will operate best with a wider LSA of around 114. That has not kept the rumor at bay that ALL blower motors need a wide LSA, a bogus notion passed from one individual to another to another to another.
Old 09-14-2010, 06:44 PM
Gears
Appreciate the "Technical Advice/Answer", to my original question. That is what I was looking for. Thanks Again.
Old 09-14-2010, 06:59 PM
runn141's Avatar
use the gears, you will notice a difference.
Old 09-14-2010, 07:17 PM
Dirty Biker's Avatar
Bold As Love
So maybe people are getting confused overlap and lsa because they do not always need to go hand in hand. A narow lsa cam can have little overlap with short duration and a wide lsa can have plenty overlap with lots duration.
Old 11-01-2010, 10:32 AM
P. Jackson Direct Dr. Gears
Ok Guys, here we go again. I too like some before me, have "Misplaced" Installation Inst. Puzzled on Clearance from Cam Gear to Eng Block & Clearance from Timing Cover to Cam Gear? Included in set, is a "Button Cap"? Which if I recall Instruction states,"Ck clearance from Cam Gear to cover by installing Cap/ Button on Gear & apply Putty to "Button/ Cap". install cover, ck for clearance?? What is Clearance suppose to be? Am i even close to what correct installation procedure should be? If anyone out there has a copy of instructions,would you be so kind as to post that step? Thanks.
Old 11-01-2010, 11:58 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Here's a couple of links and an instruction sheet for PJ gear drives.
http://www.compcams.com/Technical/In.../Files/117.pdf
stalling a Pete Jackson Gear Drive in a SPC
Old 11-01-2010, 05:15 PM
PJ Gears.
First & Foremost, Thank you for the Comp Cams link. Now that I am Retired I tend to have plenty of time on my hands & look for "Stuff" to do on my 210, 57. The way I see it "How else am I going to learn if I don't dive into it" which is exactly what I am doing. Prior to disassembly, I placed the eng @ TDC. Rotated Crank, Dist points to #1 Cyl. #1 Cyl Piston can be felt at TDC with screwdriver through sparkplug hole. Removed Timing Cover.Camshaft Gear (Top) was pointing @ 12 O'Clock. Crankshaft Gear (Bottom) pointing @ 12 O'Clock. According to Inst.sheet in Compcams link, and I quote, "The mark on the Crank Sprocket will be at 12 O'clock (Straight up) and Mark on Cam Sprocket at 6.Well quess what? Mine is as follows: Cam Gear @ 6 O'clock, Crank Gear @ 12. I know I did something wrong, now, how do I fix it? Appreciate any input. Thanks Guys. AFSOG. :
Old 11-01-2010, 05:18 PM
PJ Gears.
Misprint!! Cam Gear at 12 O'Clock. Crank Gear at 12 O'clock.
Old 11-01-2010, 05:34 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You're OK, with 12/12 with #1 at TDC, both valves closed, you're ready to fire #1. The reference on the sheet regarding "TDC" in both alignment positions, is only the pistons are at TDC, period. In one, position cyl #6 is ready to fire, in the other #1 is ready to fire.
Would be at the top of the exhaust stroke #1, top of compression #6, which it is when the dots are cam 6 crank 12 (together).
I'm not great at explaining it, but you get the picture?
Old 11-01-2010, 08:21 PM
PJ Gears.
Again Super Thanks! Maybe I am not to good at understanding the whole answer but, I did key in on your first sentence! "You're OK with 12/12 with #1 @TDC Both Valves closed.
QUESTIONS: How will this effect the Initial Cranking of Eng & setting Timing ?Will any other adjustments have to be made prior to Cranking? Thanks Again.
Old 11-01-2010, 08:33 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
It should be just like changing a chain. If aligned correctly, it should fire, you'll have to check/adjust the timing of course. The only ajustments you might need to make is for clearance between the button and timing cover. You'll need access to the cam to move it back and forth, that means intake off and make sure you don't slide the cam out too far.
4:11 gears are pain in the "rear end" renfroe453 Transmission - Rearend 7 10-17-2009 06:01 PM
Drive shaft swap, u-joints???? with pics zbhover Transmission - Rearend 6 08-16-2009 09:16 AM
Comp Cams belt drive / damper fitment SoCalJim Engine 2 07-31-2009 06:40 PM
TH 400 Speedo Gears rs67ss Transmission - Rearend 5 04-03-2005 11:58 PM
Driven, drive gear info 87442lover Transmission - Rearend 5 07-27-2004 08:11 AM
