direct drive powerglide setup help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2013, 09:42 AM
I have a request from a buddy that circle track races to build a direct drive powerglide. I've build quite a few Powerglides for circle track use but never a direct drive converterless one. He says there are guys running them and they have no clutch pedal or valve to turn off the line pressure. I see TCI sells an internal bleed valve body. Anyone ever use one? I have the book "Powerglide Transmission Handbook" but it doesn't go into too much detail and says to use the manufacturers instructions for setup. Anyone have any experience with these?
Overdrive vs. direct drive+high gear??? against all odds Hotrodding Basics 8 10-02-2012 11:50 AM
Direct Drive Gears. afsog Engine 25 11-08-2010 01:47 PM
Direct drive, converter only, no gear box Augusto Transmission - Rearend 24 06-21-2010 01:09 PM
Direct drive or Belt driven mikeweb Garage - Tools 18 07-16-2007 11:09 AM
a500 no reverse or direct drive when hot dgm Transmission - Rearend 0 04-29-2006 06:34 PM
