Dirt cheap DIY shop air dryer set up. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2006, 07:02 AM
I was killing time by browsing the forum and noticed several ppl have asked what to do about condensate in their air lines. I had the same problem and after a day or so of work and a few bucks I came up with a solution that has worked flawless for me. Below is a link to how I built my own condensate removal system and I hope it helps someone that doesnt mind a little DIY type project.
(BTW, no laughing at the flower decorations on the cabinates in my garage please...it was there when I moved in and since Ive taken a liking to it I decided not to remove it )
http://www.pro-touring.com/forum/sho...air+compressor
Old 02-06-2006, 09:40 AM
cboy's Avatar
Last journal entry: Finished
Nice set up. Just wondering if an air conditioner radiator would work in place of the oil/trans cooler. I have no idea what those units are rated at for psi - but it's what I've got laying around.
Dewey
Always learning...and sharing what I've learned.
Old 02-06-2006, 11:23 AM
brainsboy's Avatar
brains
Best thing in the world are the toilet paper canister filters. You can buy them at a paint supply store they cost about 80-90$.
Old 02-06-2006, 11:38 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Wix has a subsiduary called Aquacheck Filters that make an inexpensive spin-on compressed-air water filter (That's a bit of a mouthful)
We used to sell them at the NAPA store that I worked at.
Old 02-06-2006, 12:44 PM
302 Z28's Avatar
Problem with filters is they have to be changed. The above described system is maintenance free.
Vince
Old 02-06-2006, 01:36 PM
cboy's Avatar
Brainsboy, do you happen to know any web sites with this canister? Is it pretty much the same as the Aquacheck shown in the other post?
Old 02-06-2006, 03:31 PM
78novaman's Avatar
The AMC, FORD, & CHEVY Guy??!!
Last wiki edit: Improving fuel economy
Last journal entry: Finally on the road
You, my friend, are a genius!
I was thinking of something similar for a friend of mine that does some painting.
Now you just need to learn to stop giving your ideas away on the internet and patent them
Old 02-06-2006, 05:55 PM
jvsapp's Avatar
just a gearhead in paradise..
Last journal entry: last ones for now.
i build something simular, but like the idea of the 555 timers... that is a nice touch... i hate bending down to bleed off the compressor. but where i am at, condensation is a daily thing... even in the winters.... my radiator setup goes good for blasting about an hour before i gotta stop and drain. i use about 30Ft of 1/2" copper tubing plus a water trap. then the 100 ft 3/8 line to a small trap, and i occasionally still get some water at the tool end.
Old 02-06-2006, 06:48 PM
Thanks for the compliment but in reality Im prolly closer to being classified as "cheap" in that I build something I need if at all possible before buying it.
Ive used this set up to paint a couple of projects so far with no problems so far. I do still use the small disposable filters that are normally seen attached to the air line connection at the paint gun for extra insurance though.
I looked into that on another idea/project and for your average blue collar Joe Schmoe like me it was WAY more than I could afford when it came to hiring a lawyer to do the patent search as well as the multi page submittal form that is ~3/4" thick .
The 555s are prolly a little more complicated than needed to be but its what I had in my electronics junk box at the moment.
I just noticed your location and I can see why condensate would be an issue. While Im no expert I bet a condensor with more area than mine as well as an automated drain set up with shorter blow down times than mine would help if not cure completely any moisture issues.
As you can see in the pics I dont have anywhere near that length of copper line and Ive never gotten a single drop of water at the tool end even after 6-8 solid hours of die grinder work. As I mentioned an educated guess is that a bigger condensor shorter intravels between blow downs along with your existing copper tubing length would help a lot.
Anyways, I hope my little project either helped someone with a condensate issue or inspired someone to improve on what I did so that works even better.....and thanks for not giving me grief about the flower decorated cabinates in the garage .
Old 02-06-2006, 06:56 PM
jvsapp's Avatar
nothing wrong with a little "flower power".... but yeah i really like your idea on the 555 timer. it has been years since i used my breadboard... maybe i should take it out and see what i can get going. where did you get the solenoid valves from? any idea on the cost?
thanks, JD
Old 02-06-2006, 06:57 PM
Dewey
Dewey,
Im guessing an AC condensor would work as far as pulling the moisture out of the air but since I really dont know what pressures HVAC stuff is good for I cant say for sure. Maybe an HVAC guy on here could chime in and let us both know but if it was me I would be leary of it. As Im sure youre aware if HVAC condensor was to fail due to over pressure the shrapnel would be potentialy lethal .
Old 02-06-2006, 07:02 PM
jvsapp's Avatar
i was setting up an old yorkshire AC compressor to make a mini junkyard compressor running from a 5hp B/S motor, and from the article i read the yorkshire compressor puts out 400psi, possibly the high pressure side of the AC condensor should handle the 120psi normally from an air compressor. i kind of like the idea on the ac condensor too... might be over kill though... with my 30FT 1/2"copper radiator already, but then again, we do ahve a lot of moisture out here averaging out to 80% humidity year round...
Old 02-06-2006, 07:09 PM
thanks, JD
JD,
The valves came out of a large HVAC control panel that I found at a non auto metal scrap yard. While its only a guess on my part it looks like older large HVAC set ups are pneumatically controlled since the schemtaics inside the panel that was full of these valves had labelling "reheat circ to shipping" as well as other labels that named various parts of what seemed to be a manufacturing plant.
Anyways, I pulled a hand full of the valves out and stashed them in my "parts that I might need one day" pile but since the valves came in a panel I salvaged I dont know the individual price but Im guessing that ppl like MSC Supply, Grainger, or similar carry them. I would be more than happy to get a part # and manufacturer off the label on them if that would help you.
Old 02-06-2006, 07:15 PM
jvsapp's Avatar
that would help. i do remember getting a pneumattic catalog a few years back(well 12 years since i been out of tech school) that had some 12v solenoid valves. guess i gotta go dig that up...
thanks, JD
Old 02-06-2006, 11:35 PM
First PUT A GUARD ON THAT FAN! Anyway nice set-up
Cboy, I have a buddy that has a Ford Ranger evaporator core rigged similar to that trany cooler and it works really good but it is on a small compressor. The core was tested to 175 PSI and is operated at 120 max but I am fairly sure it would safely run much more pressure than that, it would be simple to test it first. Whatever type of cooler is used make sure the inside tubes lay horizontal and not vertical since the loop at the bottom, if vertical, could cause problems.
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
air lines CARGUY Garage - Tools 96 11-16-2006 05:11 PM
FRAM air breathers!!!! Robbie Engine 70 09-22-2005 06:52 PM
idea for cheap respirator air supply... deuce_454 Body - Exterior 4 04-20-2004 09:51 AM
Custom air filter set up.. Trav Engine 4 02-13-2004 07:02 PM
