dirty Honda gas tank - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2013, 06:22 AM
I have a Honda Accord with rust in the gas tank. I don't know if there is any way to prevent this from getting into the injectors. I wonder if there is a good enough fuel filter to accomplish this. Does anyone know about this who could advise me?
Old 01-21-2013, 06:35 AM
Banned
You will change filters weekly, your tank is still rusting and mixing with the fuel & entering your motor. You need to drop the tank have it cleaned & Sealed.
Old 01-21-2013, 09:59 AM
Drain the gas from the tank. Drop the tank and clean it the beat you can with simple green or some type of degreaser. Main thing is to get rid of all the gas fumes. If you have a radiator shop nearby take it to them and see if they will dip it and clean the rust out. If the cost is too high get another tank from an auto recycler.
Old 01-21-2013, 11:31 AM
You didn't specify what year or model Accord, but given how common these cars are, I wouldn't even screw with it. Just get a replacement tank. Oh, and change the fuel pump while you have the tank out.
Old 01-21-2013, 12:23 PM
Thank you for your replies. I've found a shop nearby who will clean it.
One of you mentions replacing the fuel pump. Is it not possible to flush it or clean it in some other way?
Old 01-21-2013, 12:40 PM
The electric fuel pump is in the tank and you need to drop the tank to replace it. This is one of those "might as well do it now" things. If you don't replace it while the tank is out for cleaning, you can guarantee that you'll be dropping the tank again in a few months to replace it then.
Is this Gas Tank neck bad? Tank? Clean it? Leave it? gotmud Engine 2 07-06-2011 12:43 PM
Installing a gas tank from a 1996 honda passport into a 1938 ford pick up project. 38fordpu General Rodding Tech 6 11-26-2008 06:38 PM
Dirty looking gas, filter problems ScoTFrenzel Engine 10 09-07-2008 08:06 PM
gas runs back to gas tank... 66nova guy Engine 7 12-28-2003 04:35 AM
Need Tank Sender for Custom Gas Tank.... bg Engine 3 11-05-2002 05:13 PM
