Dirty plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2002, 10:47 AM
New Member
Post Dirty plugs
Hey i have a 78 camaro and my spark plugs always are going bad go bad way to fast why would these be doing this please help thanks!
Old 10-13-2002, 11:55 AM
New Member
Post
when you do mean oil fouled. are they going bad in a week.if so it is your valve guides,valve seals,and even the piston rings. maybe its time to rebuild the engine.
Old 10-13-2002, 12:43 PM
E.T. divided by $ spent= Speed
Post
Yep.I had a 305 w/ 250,000mi on it plugs ould foul in 3 days would start skippin etc...Would drip oil out the tailpipe.Do gotta admit though held it to the floor for 15min in neutral to blow it up at junkyard time but she heald together,screamin 4000rpm and blowin out oil like it was designed to.
Sounds like rebuild time.
Old 10-13-2002, 04:06 PM
Post
had same problem with my 350 chevrolet. It could be timing,leaking valves,ortime to rebuild.
Old 10-13-2002, 05:28 PM
New Member
Post
You might have Plugs that have too cold of a heat range. Double check to see if they are the right ones and gapped properly (not too much gap). If the heat range is too cold the plugs will not "burn" off the deposits that build up on them. If the heat range is too hot the plugs will cause a hot spot in the engine and can lead to detonation and pre-ignition, so be carefull if you go up in heat range. Good Luck...
[ October 13, 2002: Message edited by: 72trucker ]</p>
