DIS where there wasn't one before - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2006, 08:35 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I'm putting a Caddy 500 into a highly detailed engine bay. The 500 will have nice covers fabricated for certain areas to really neaten it up... except for that damn front-mounted HEI.
This will be converted to EFI on a megasquirt and (since I'm an ignition dummy other than making good curves), how would one go about piecing together a DIS where there was none? How do you ditch the distributor and still drive the oil pump? I know megasquirt does a spark box that will handle a DIS, as does MSD, but that's about where my knowledge ends. Any ideas?
Old 06-02-2006, 09:05 AM
MustangSix's Avatar
Megasquirt II has an ignition function embedded. It will drive the Ford EDIS box.
Old 06-02-2006, 08:00 PM
I think you need to ask these questions on the megasquirt web page.
As for the oil pump I don't think it would be too hard to cut down a dist housing just for the oil pump. You might also want to keep the reluctor in there...but that is something the MS guys will tell you about.
Old 06-03-2006, 07:21 PM
curtis73's Avatar
Wiki Edits: 16
I'll check with the MS guys, thanks.
About the oil pump drive... if I cut off the housing and shaft, then tap the housing for a bolt I can set endplay on the shaft... but will the shaft want to push up? Will the shaft push up against the bolt galling it and sending metal shavings into my engine?
Old 06-03-2006, 07:26 PM
The gear and shims on the bottom would keep the shaft from going up. You would need to do something to keep it from going down (I wouldn't trust the oil pushrod) and keep the dirt out.
'74 Ford Courier 1.8 L.Points Dis. Fit... AmericanPackMule Engine 0 03-07-2006 04:38 AM
DIS ignition, Visteon Corp. coil on plug / MSN coil per cylinder Costa Rica Electrical 0 06-30-2005 02:13 PM
mallory dis. rebuild. how do you do it 1967stang Engine 1 07-23-2004 04:40 PM
how do i change the resistance wire that runs to my dis? IHAVECHEVYPARTS Electrical 1 12-23-2002 11:55 PM
new brass insert dis. cap still have to scrape it to start it IHAVECHEVYPARTS Electrical 2 12-18-2002 03:21 PM
