Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - disabling rear drum brakes
Old 03-14-2006, 05:47 PM
matt167 matt167 is online now
Wiki Edits: 31
a cheap way would to take a ball valve of the correct NPT size and put it in the line to the rear by double flaring and putting 2 new ends on, with the inverted flare adapters, thread it up tight, when you want them off, close the ball valve, and no rear brakes.
