-   -   disabling rear drum brakes (http://www.hotrodders.com/forum/disabling-rear-drum-brakes-84162.html)
nitro3421 03-14-2006 11:22 AM
I have a 72' Chevelle with rear drums and front discs. Can anyone tell me a quick an easy way to disable the rear drums for a burnout then enable them fairly quickly again?
Thanks for the help!
curtis73 03-14-2006 11:57 AM
Put a line-loc on the front. Its an electric valve that holds brake pressure on the front after you let off the brake. Rear wheels are free to do as they please.
nitro3421 03-14-2006 04:31 PM
Nice suggestion, thanks for the help
matt167 03-14-2006 05:47 PM
a cheap way would to take a ball valve of the correct NPT size and put it in the line to the rear by double flaring and putting 2 new ends on, with the inverted flare adapters, thread it up tight, when you want them off, close the ball valve, and no rear brakes.
