disabling rear drum brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2006, 11:22 AM
New Member
I have a 72' Chevelle with rear drums and front discs. Can anyone tell me a quick an easy way to disable the rear drums for a burnout then enable them fairly quickly again?
Thanks for the help!
Old 03-14-2006, 11:57 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Put a line-loc on the front. Its an electric valve that holds brake pressure on the front after you let off the brake. Rear wheels are free to do as they please.
Old 03-14-2006, 04:31 PM
New Member
Nice suggestion, thanks for the help
Old 03-14-2006, 05:47 PM
Wiki Edits: 31
a cheap way would to take a ball valve of the correct NPT size and put it in the line to the rear by double flaring and putting 2 new ends on, with the inverted flare adapters, thread it up tight, when you want them off, close the ball valve, and no rear brakes.
Ford Rear Discs Cobbled Together Psquare75 Suspension - Brakes - Steering 34 11-21-2005 03:47 PM
rear drum brake problems 58Delray Transmission - Rearend 1 09-19-2005 07:07 AM
87 iroc rear disc brakes dont work camarofreek Suspension - Brakes - Steering 4 07-18-2005 10:10 PM
I-beam axle with drum brakes...Help! 26trackt Suspension - Brakes - Steering 3 11-22-2002 07:25 PM
Ford Explorer Rear Disc Brakes Lloyd Topping Jr Transmission - Rearend 4 11-10-2002 02:06 PM
