Disappointed with dyno numbers
I went to the dyno the other day and I am really disappointed. You be the judge.
Here is my setup Std bore 350 Rpm Air Gap Holley 670 street avenger Vortec Cylinder heads minor work with 1.6 rr comp cams 282hr 230/236 110 LSA 9.6 comp ratio 700r4with a TCI street fighter torque converter Ford 9" w/ 3.50 gears Power results were 283rwhp 292 ftlbs torque A/f was between 13-14. When I was talking with comp cams I was shooting for 400hp at the crank. They told me this would get it close they calculated 396hp and 424 tq. Am I over reacting or is this about right? Last edited by lowrides10; 06-28-2008 at 11:19 PM. |
What they told you should be close.
Your problem is most likely in the stock transmission, or the kick-down/detent cable adjustment. The dyno shop should have checked the adjustment though. Just because you install a TCI torque converter does'nt mean your transmission is "up to snuff". |
Whats the exhaust setup?
Do you have the ignition curve dialed in yet? Usually you need at least a 290HP/R cam to get near 400 HP in my experience, from the looks of it your getting near 325-340Hp at the crank if you consider loss through the trans. The torque seems a little low though thats why I mention the ignition curve. |
The exhaust is hedman shorty headers. Through H pipe 2.5" with borla mufflers then dumps. As far as the timing they took all advance out vacuum and mechanical it is locked at 36*.
It'sa 700 R4
283 hp divided by 77% = 367 hp. I think this is about right for what you have. Locked distributor is a bad idea, IMO. Good tuning might sneak a few more. Remember every dyno is different. Numbers are only valid on one dyno for tuning purposes from run to run improvements. |
A final thought
Seemingly identical engines can easily vary 40 hp due to ring type and wear, valve job, valve type, push rod deflection, spring harmonics, carb tuning, and numerous other often overlooked factors. |
| Recent General Rodding Tech posts with photos |
| 383 dyno numbers dissapointing | mattson70 | Engine | 53 | 05-05-2007 02:51 PM |
| Can someone run these numbers on there Desk Top Dyno? | black66 | Hotrodding Basics | 7 | 06-02-2004 02:52 PM |
| Final DYNO numbers!!! | jonathanks | Engine | 1 | 03-25-2004 11:25 AM |
| Second Time Round, Dyno NUMBERS!!!! | jonathanks | Engine | 15 | 03-25-2004 10:55 AM |
| Less than Stellar Dyno Numbers | Todd Hot Rod | Transmission - Rearend | 13 | 09-19-2003 01:46 PM |
