Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Disappointment with new cam/head swap
Old 07-06-2009, 10:32 AM
lmsport lmsport is offline
I would not use Comp Cams if they were free, UNLESS is is a custom grind, then they seem to work fine. I have have had the exact same experience as yours and ultimately it was the cam. In Fords, Chevs, and most recently a AMC. The 401 ran OK with the Comp Cam, about the same as the stock cam that it replaced, but after swapping it to a Isky, it ran like it should.
