Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Disappointment with new cam/head swap
Old 07-06-2009, 01:09 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Chevy21
Could these springs be too heavy for the cam I am using?
The spring rate has nada to do w/the current problem.
If you are absolutely positive the ignition timing is fine, I'd suspect the cam/timing chain and gears has been installed a tooth off.
