Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Disappointment with new cam/head swap
Old 07-06-2009, 01:11 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
I`m curious, did you use the same Quadrajet carb when you got the performer RPM? if the performer RPM is a square bore pattern the Q-jet will bolt up but the secondary`s will not work due to it being a spread bore carb. I sure hope that`s not happened. Next is, where is the vac advance connected to? a ported or a manifold vacuum source?
